pinion/ ring gear exchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2004, 09:43 PM
chevyman06's Avatar
I was wondering if i could take the pinion and ring gear from a 8 1/2 inch rear end and put the ring gear on a 7 1/2 inch houseing, and will the pinion fit?
Old 06-24-2004, 01:10 AM
DoubleVision's Avatar
No.
Old 06-24-2004, 05:47 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
And you cannot go the other way either, And as long as we are at it...
A ford 7.5 WILL NOT fit in a GM 7.5 inch axle either.
