Pinion shaft jammed, 1986 camaro rear end
How do you get a jammed pinion shaft out? It is out of the first gear but cannot get it to advance any further to get it out of the carrier? We are trying to replace a rear axle oil seal. It is in a 1986 camaro rear end
1986 chevy rear end
We have restored a 1953 gmc pickup truck. We used a 1986 engine transmission and rear end. We are trying to replace a rear axle seal. We have to removed the pinion shaft to get the C ring on the axle. The bolt was broken but we got the shaft 1/3 of the way out. Now it is jammed. It is out of the first gear but we cannot get it to advance any further. We are stuck!! Any ideas?
joe1953gmc,
Welcome to hotrodders.com I edited the thread title, I also merged your 2 threads on the same subject into one Please do not use 'help' as a thread title. Give the members here some information on the problem you have like the vehicle make - year , transmission where the problem may be at
At the Bonneville Salt Flats, first gear is known as 130 mph. |
We tapped it until it almost hit the pinion and it came out of the first gear and now it is stuck. Tried tapping it back in and will not move. The shaft will not move in and will not move out. The bolt broke off and some of it was still in the shaft. Broke off far enough in that it did not get in the way to advance towards removal. We are still stuck. Looks like cutting the pin with a torch is a great idea. Thank you.
| Rear differential pinion shaft problems | Kamp | Transmission - Rearend | 0 | 06-06-2011 10:35 PM |
| 67 Camaro rear end needs new ring and pinion | bhauto1016 | Transmission - Rearend | 1 | 05-03-2011 11:09 AM |
| Pinion shaft bearing? | chevyrally68 | Transmission - Rearend | 4 | 11-29-2010 03:13 PM |
| Off-set Pinion Shaft | dchatcher | Transmission - Rearend | 25 | 05-12-2009 07:39 PM |
| 1986 s-10 truck steering shaft linkage worn? | fumplet | Suspension - Brakes - Steering | 4 | 07-21-2006 10:42 PM |
