Pinion yoke u-joint "clamps"? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2006, 10:53 AM
XNTRCI-T's Avatar
AKA Lee in KC
I'm putting a salvage yard '98 S10 Blazer rear-end in my T-bucket (please, no lectures about how wimpy this rear-end is, I plan to change it out for a Jag IRS when I find one!). The little clampy-things that hold the U-joint to the pinion yoke are missing. Went back to the yard where I got the rear-end and they didn't have any. What is the technical name for these things, and where would one be able to get them?
Edit: NEVER MIND... went to a "driveline" specialty shop and they had 'em! By the way, they're called "straps."
Old 06-09-2006, 12:47 AM
NAPA has them.
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 10:02 PM
TH350 driveshaft yoke leaking Jmark Transmission - Rearend 11 08-16-2008 12:38 PM
how to determine correct pinion angle upthcreek Transmission - Rearend 2 12-22-2005 08:58 AM
penion angle wolfemanbud Transmission - Rearend 2 10-04-2005 07:58 PM
Pinion yoke weight??!! catscan4free Transmission - Rearend 0 01-28-2004 08:25 AM
