Pinstripe Removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2007, 09:52 AM
Pinstripe Removal
I just bought a 93 Toyotafor my wife to drive for work and the paint is in need of some work and the pinstriping along the upper body line is bad. what is the best way to remove the offending stripe so I can detail the body and then replace the stripes?
Woody
Old 01-01-2007, 10:31 AM
stripe removal
I would use a heat gun or hair dryer to loosen the stripes, then you should be able to pull them off. Then clean any glue left with "GooGone"
Old 01-01-2007, 04:03 PM
PRO 48 fleetline's Avatar
Last journal entry: Csr Electric Water pump
if the stripe has been on and baked on after years of uv damage you can purchase what is called a rubber ripping wheel it connects to the end of your air speed drill and is made up of eraser material and dosent damage the paint takes stripe and glue right off
Old 01-01-2007, 04:25 PM
adtkart@aol.com
Here they are known as "Eraser Wheels" and cost about $10- $15. They do a great job of removing stripes and 2 sided tape from moldings. They are made for special grinder type of tools, as they have threaded shafts, but can be chucked up in a hand drill.
Aaron
RE: Removal & Install Camshaft Bgcooley Engine 7 11-05-2006 06:34 PM
Silver leaf pinstripe help jschulze Body - Exterior 2 06-08-2006 11:27 AM
Th350 seal removal SBC-S-15 Transmission - Rearend 1 04-04-2005 09:41 PM
Ignition Cylinder Removal brettc Interior 1 09-14-2003 09:50 PM
pinstripe residue removal mitmaks Body - Exterior 1 06-13-2003 06:59 AM
