Pinstriping 100 yo bead roller - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2010, 07:41 AM
BWS BWS is offline
Got a 100 yo bead roller thats nearing completion,gorgeous cast legset that is reminiscent of other machine tools in that era(South Bend lathe looking).Anyhow,I shot it gloss black with SW enamel w/hardener.......now I want to do some VERY minimal,tasteful pinstripes on legset as well as the cast in,makers name.What would be the prefered type of paint?Is lacquer(because of fast drying)OK?Thanks abunch BW
Old 05-26-2010, 09:36 AM
"What would be the prefered type of paint?"
Sign Painter 1-shot enamel, you can get it at Eastwood.com
Dupont's Imron urethane enamel, get it at a local jobber, but it doesn't come in bright red. No need for hardener, it dries well alone.
Old 05-26-2010, 09:55 AM
milo's Avatar
point on positive
It's gonna be fun ...
Get a big piece of glass or mirror ,, practice then razor blade it clean and practice , then repeat ...
clicky--> http://www.a2zautoforums.com/showthread.php?t=3934
Old 05-26-2010, 01:48 PM
BWS BWS is offline
Cool
1-Shot sounds great........will give Eastwood a call.Now must decide on either silver or a straw yellow.Thanks,BW
Old 05-27-2010, 05:55 AM
milo's Avatar
point on positive
right here right there ,,,
The coolest site out there for ideas
--> http://www.pinheadlounge.com/
bead roller, home made nissan Garage - Tools 7 02-22-2011 11:53 AM
Hi from Pinstriping UK PinstripingUK Introduce Yourself 1 10-23-2007 11:53 AM
Using a bead roller...backwards... AngliaBob Body - Exterior 2 02-20-2005 09:19 PM
Using a bead roller backwards??? AngliaBob Body - Exterior 0 02-18-2005 07:21 PM
Roller cams MI2600 Engine 4 11-28-2002 07:40 PM
