Pinto Manual Rack swap.... and Hello! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2003, 05:15 PM
New Member
Post Pinto Manual Rack swap.... and Hello!
Ok First off let me say hi to everyone here and I hope at some point I may be a source of info for someone or parts...
Ok my question for you Ladies and Gentleman is ... I have a 1978 Pinto Wagon with a 2.8 V6 which is getting a needed displacement upgrade to a 302 V8 and C-4 tranny. BUT...In order to get the car safietied I have to replace the rack soooooo I figured swapm to a mustang II rack...logical right.... get rid of that dirty PS pump all that extra weight ....ect. But What year Mustang II, what are all the specifics in this swap ,... I just need a little insight.
Too many cars that I own or want to list....not enought time or money....
Old 04-10-2003, 05:39 PM
BOBCRMAN@aol.com's Avatar
Post
A good parts man will be able to tell you the exact interchange.
Old 04-10-2003, 05:40 PM
New Member
Post
The problem is that I am new to Calgary and don't have a good one yet
Old 04-11-2003, 08:38 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Post
Mustang II and Pinto use the same rack. A standard rack will fit, but you might have to get the inner tie rod ends (the entire rod) as well, since lengths may be different. Unless they've been replaced at some point you really need them anyway. I recently put a salvage yard rack in a car and the tie rods had a bit of play in them. As far as I can recall the power and manual racks use the same mounts, but the shaft for the manual is longer by 4-6". The collapsible shaft might expand that much, not sure.
Old 04-11-2003, 03:00 PM
New Member
Post
Well you are right the te rod ends are totally shot, So what you are reccomending is just buying the 1978 Mustang Rack and the tie rod ends? Straight swap,... right in? <img src="confused.gif" border="0">
Old 04-11-2003, 03:24 PM
Post
Jennsen, The 74-78 Mustang II are dimensionally the same as the 74-80 Pinto and Bobcats. However, there are some mounting differences between power and manuak racks but that only is a factor replacing manual with power. If you were loooking at other power racks, there was a ratio change in the later racks and the flared fittings gave way to O ring seal type fittings, again no factor in power to manual swap.
Good hunting.
Trees
Old 04-13-2003, 06:40 PM
New Member
Post
Ok I have ordered my Rack for a 1978 Mustang II how bad is this swap? Am I gonna have to get the mig out? Sorry to ask all these questions its the anticipation thats killing me. If I had the part in front of me I could atleast start planning <img src="confused.gif" border="0">
Old 04-16-2003, 04:44 AM
EBlack36's Avatar
Rebuilt Excitment
Post
I have changed the Manual rack on my street rod to a power unit, some of the minor differences are some early units used 2 mounting holes and others used 3, the outside mounts are the same and the splines to hook up your steering are a larger on the power rack over the manual. The inner and outer tie rod ends are also different. I bought a rebuilt rack at the parts house for under 200.00 a couple of years ago, I use a lot of salvage yard items, but I did not want any leaks and if I remember correctly it came with the inner tie rod ends.
Old 04-16-2003, 02:37 PM
New Member
Post
[quote]Originally posted by EBlack36:
<strong>I have changed the Manual rack on my street rod to a power unit, some of the minor differences are some early units used 2 mounting holes and others used 3, the outside mounts are the same and the splines to hook up your steering are a larger on the power rack over the manual. The inner and outer tie rod ends are also different. I bought a rebuilt rack at the parts house for under 200.00 a couple of years ago, I use a lot of salvage yard items, but I did not want any leaks and if I remember correctly it came with the inner tie rod ends. </strong><hr></blockquote>
I bought the manual rack, tie rods already, the splne shaft you speak of are you talking about where the steering coloum meets the rack?
Old 04-17-2003, 04:49 AM
EBlack36's Avatar
Rebuilt Excitment
Post
That is exactly what I mean. Good Luck.
Old 04-19-2003, 05:35 PM
New Member
Post
<strong>That is exactly what I mean. Good Luck. </strong><hr></blockquote> Good luc?? that doesn't sound promising...
Old 04-19-2003, 08:15 PM
4 Jaw Chuck's Avatar
Post
This post should go in the database. Good info here!
— Han Solo
Old 04-27-2003, 01:15 PM
New Member
Post
OK with the new tie rods the rack bolted right in!!, I have all the part #'s if anyone needs them. Not I just need the piece that connects the steering knuckle to the rack! OFF to the Junk Yard! <img src="graemlins/evil.gif" border="0" alt="[evil]" />
Old 04-27-2003, 10:58 PM
New Member
Post
OK its totally in, I had to grab the steering shaft from a older Pinto with a Manual rack (freeklin hard to find!) and its totally in. It's freekin sweet! FENCO Part # RP8353 (1978 Ford mustang II manual Rack) It is WAY chaeper than the Flaming River Rack!
Now ts time to stuff the 302 and C4 n it!!! <img src="graemlins/evil.gif" border="0" alt="[evil]" />
[ April 28, 2003: Message edited by: JENSSEN ]</p>
