Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinto Manual Rack swap.... and Hello!
Old 04-16-2003, 04:44 AM
EBlack36's Avatar
EBlack36 EBlack36 is offline
Rebuilt Excitment
Post
I have changed the Manual rack on my street rod to a power unit, some of the minor differences are some early units used 2 mounting holes and others used 3, the outside mounts are the same and the splines to hook up your steering are a larger on the power rack over the manual. The inner and outer tie rod ends are also different. I bought a rebuilt rack at the parts house for under 200.00 a couple of years ago, I use a lot of salvage yard items, but I did not want any leaks and if I remember correctly it came with the inner tie rod ends.
