Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pipe or boxed crossmember
Old 01-21-2013, 10:30 AM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
If you think pipe is gone to be stronger.. Go for it... But if you have a press give it a little test and see if your wrong or not..
I think you will be surprized at the result...
As far as the welding goes.. When done right you get the same result's tubing or pipe as far as stress goes..
This might give you some ideas..Making A Willys Frame !!
