Pipe or boxed crossmember - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2013, 02:12 PM
So I'm putting a chev 350 into my 53 gmc pickup so now I have to replace my crossmember. what I was wondering is whats the difference between using a boxed plate crossmember to using a single piece bent 3" pipe?
Old 01-19-2013, 02:21 PM
life is a temporary assignment
Tubing is stronger because of the corners,, But I have use both for a crossmember.. Not as big as 3'', But have used both with no problems..
When you have the pipe welded are bolted in it will be pulling on both side of the frame to break in half..The 3'' isn't as important as the thickness would be....
Old 01-19-2013, 02:39 PM
Banned
boxed.. if you ever go ifs as the engine crossmember keeps the mounting points of the frame true.. if sticking with a live front axle,
either.. as long as it hold the engine..
Old 01-19-2013, 02:55 PM
Sorry... I thought you was talking about the trans crossmember...
Front cross member Box it..
No pipe !!!!
Old 01-19-2013, 07:57 PM
Originally Posted by hcompton View Post
For the trans you can buy nice prebent 2x4s ready to make plates for bolting in. Do not use round tube it will not give good bolting or welding surfaces.
For front engine cradle it should be boxed up. If not already may want to replace if its not a nice heavy junk of steel. That section of the frame should be very strong.
Trans crossmember is just to hold the trans and support.
The front member is structual and very important to how well your finish project will drive and handle real world conditions.
I agree with some you posted but round tubing can be used very easy..Here's one I did using the round tubing.. And you can unbolt it if you needed too..
Here's another one I did with 1''x2'' tubing,, The very samething can be done with pipe,, As far as the front crossmember.. Boxing it is the only way to go..
ID:	70732   Click image for larger version
ID:	70733   Click image for larger version
ID:	70734   Click image for larger version
Old 01-21-2013, 10:15 AM
The reason I would like to go pipe is because when you put that much weld into A boxed frame like that your going to end up with distortion from the heat. Even if you jig it up your still going to be welding stress into it. Where as the pipe just has two end caps then welded to the boxed frame. Plus I can't bring my self to buy a cross member as I have a pile of steel here in the shop to build my own. From a strucal aspect I think the pipe would be stronger then boxed plate, I could use hss but I still want to get away from putting to much weld into it.
Old 01-21-2013, 10:30 AM
If you think pipe is gone to be stronger.. Go for it... But if you have a press give it a little test and see if your wrong or not..
I think you will be surprized at the result...
As far as the welding goes.. When done right you get the same result's tubing or pipe as far as stress goes..
This might give you some ideas..Making A Willys Frame !!
1/2 pipe to male 1/4 pipe thread for shop Mach1460 Garage - Tools 8 09-27-2011 09:38 AM
Flexible Pipe from Compressor to Solid Pipe? cab Garage - Tools 24 12-03-2007 07:55 PM
Homemade boxed control arms FiveFeezy Suspension - Brakes - Steering 3 02-28-2007 08:53 PM
Schedule 40 pipe for trans crossmember? VEGA 3503508.5 Engine 18 10-05-2006 07:24 PM
welded in boss' for boxed frames bhj General Rodding Tech 4 05-03-2004 12:29 AM
