Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pipe pvc or not
Thread: pipe pvc or not
  #28 (permalink)
Old 03-07-2012, 05:50 PM
gow589's Avatar
gow589 gow589 is offline
the Clever Turn Signal
By the time you start adding up you can get fairly close to price to a fairly nice air system. I set up a system with the Rapidair using the 3/4" duratec line good to 200psi. It was easy to set up and does away with most metal pipe issues. Byt he time you add up pipe and fittings it's worth comparing how close you came to a system like this:
