Pipe Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2006, 09:29 PM
txdrifter's Avatar
cap'n crunch
Last journal entry: Project Monte
Pipe Question
I was in Home Depot today and was looking at some 1" copper Pipe
and it was $45.00 for a 10' section. What I was wondering is if I use
Black pipe or Gavanized do I need to use some kind of pipe dope or teflon tape at the joints since there thereadedthanks......Randy
Old 07-26-2006, 09:32 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Yep, use teflon tape......... I would use the galvanized pipe if its for a air line because it does not rust. If its for a gas line you will have to use the black pipe.
Old 07-26-2006, 09:56 PM
66ImpSS396's Avatar
It's been fun
Pipe answer
Knowing what you want to do with the pipe might affect the validity and safety of the answer?
Old 07-26-2006, 10:02 PM
Lost in the 60's
Wiki Edits: 4
66 made a good point........Why don't you tell us what the pipe will be used for.
Old 07-27-2006, 12:13 PM
txdrifter's Avatar
cap'n crunch
Pipe Question
Im sorry I didnt say what it was for.I am going to use it to plumb air lines in my Shop
Old 07-27-2006, 12:31 PM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
Yes, use galvanized and yes, use lots of teflon tape.
Old 07-27-2006, 01:06 PM
I am an avid believer in copper pipe for air lines and until now I would always suggest it first, BUT with the prices of copper today I too recommend galvanized.
Old 07-27-2006, 01:32 PM
txdrifter's Avatar
cap'n crunch
Pipe Question
Yes Red I wanted Copper.That is untill I priced it . But now the question is when using teflon tape dont you have to lay it on the way you twist the pipe so you dont tear it off once again thanks for the answers guys.....Randy
Old 07-27-2006, 01:54 PM
Lost in the 60's
Wiki Edits: 4
Wrap the teflon tape on in a clockwise direction with the end of the fitting facing you.
Old 07-27-2006, 07:00 PM
I used all galvanized pipe and it wasn't that bad since I could borrow a pipe threader. I would use a pipe thread sealant available at Home Depot called Rector Seal, good stuff! I had zero leaks and am running a two stage compressor with 175 psi shut off.
Name:	IMG_0777 (Small).JPG
ID:	13669   Click image for larger version
Name:	IMG_0779 (Small).JPG
ID:	13670   Click image for larger version
Name:	IMG_0780 (Small).JPG
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
Flexible Pipe from Compressor to Solid Pipe? cab Garage - Tools 24 12-03-2007 08:55 PM
H pipe vs x pipe Derkyb Engine 1 01-18-2006 11:01 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 11:25 AM
