Piston to bore clearance in .010 rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2009, 12:05 AM
I bought a set of custom JE pistons for my 417sbc build used real cheap.
They are for a 4.135 (.010 over) bore with 1.052 compression height.
Anyway, I ripped the 400 down today and put a piston ring at the top of the bore. Using the piston ring as a "machinests square" to measure the width of the ring plus the inside diameter of it I figure my virgin bore 400SBC to be 4.140-4.142 between cylinders.
It ran fine with stock 4.125 pistons just not great, now im after a performance build and want to clean up the bore. If I bore/hone it to 4.142 will the .007 piston to bore clearance cause any issues?
Using a basic forumula when the piston warms up to 300f/148c (wild guess) the piston will expand .008 inches. What kinda answers am I looking for here other than the obvious buy a set of 20 thou pistons. Thanks!
Old 03-07-2009, 12:39 AM
ericnova72's Avatar
More for Less Racer
You're #'s don't add up. 4.135" bore piston will be something like actual diameter of 4.128" so that they will fit in a 4.135" bore at .008" clearance. You are probably looking at .012" clearance now and probably .015"+ after just honing if you are lucky and there is no taper or out-of-round condition to the bores. If there is no taper or roundness issues then congrats, you've managed to find a needle in the haystack-- a 400 that doesn't need boring, but you are still too big for the pistons you have. If the 4.142" # is actual, you will be lucky to clean it up at +.030" overbore (4.155"). You have to have enough material there to cut solidly with the boring bar.
Sounds as if your understanding of how piston and bore sizing is arrived at is a little lacking. Pistons are smaller than the bore size they are meant to be installed in by the amount of running clearance specified by the manufacturer. Example: A piston for a 4.155" bore with a clearance spec of .005" will only be 4.150" in diameter.
Only place those +.010" pistons can normally be used is in an aftermarket block. Probably not what you wanted to hear.
Old 03-07-2009, 12:21 PM
406 bug's Avatar
9.82 @ 139mph
.007 - thats toooo much piston to wall. You need to contact JE and see what they recommend for that piston and your application. I would guess you need more like .0035. Also make sure you get info on how and where to measure clearance.
Old 03-07-2009, 01:09 PM
Well the skirts measure 4.135 and the crown measures 4.100 they are actually out of a ford nascar engine or soemthing? ebay steal. They have a gapless second ring.
I also read 4 Jaw chuck on a recent topic regarding piston to bore post "Generally 0.001" per inch of diameter is a good rule of thumb, for forged pistons it is more like 0.0015" to 0.002" per inch of dia to accomodate the denser material expansion. More than this and the rings will wear faster due to the piston rocking in the bores. I have successfully run 0.007" clearance in 4" bores with cast pistons with a light knurling on the piston skirt to prevent piston rock. Is this recommended? Not really, but it works.
If you want to go ahead and run it the way it is, she will still run OK but the rings will leak down more in that cylinder and won't last as long as the others. How much I can hear you asking? lets just say the pistons/rings will out live the valves. Personally I would just stick her back together and don't worry about it, too much clearance is good insurance against break-in seizure and most shops put in a little more just to be on the safe side. I always do on my own engines."
I suppose I'll see what the machine shop is, and throw the pistons on ebay with buy it now to make my money back if someone wants them, if not I may be taking my risks.
I will check for out of roundness today, I never thought about that, thanks!
Old 03-07-2009, 01:22 PM
DaSouthWon's Avatar
I put up the tools against$300
You may already know this but be aware that the skirts are not a perfect cylinder shape, they are barrel shaped. So the middle of the skirt is going to have a larger circumference than the bottom of the skirt. Forged pistons will also require a greater tolerance because they expand more than a cast piston.
Old 03-07-2009, 10:26 PM
racecar100's Avatar
That is the standard clearance for JE Pistons at .007.
Old 03-08-2009, 02:06 PM
406 bug's Avatar
9.82 @ 139mph
You are misinformed. There is not a standard. It depends on several factors like use/application and type of alloy used. For example, 2618 alum. can handle a rather tight clearance of .0035 - 0045.
Old 03-08-2009, 02:59 PM
techinspector1's Avatar
Wiki Edits: 326
This is from JE's site.
Basic clearances....
BORE RANGE ...............2618 CLEARANCE......4032 CLEARANCE
SB applications 4.000"-4.200" .0035"-.0045" .0020"-.0025"
Additional clearances to be added to the above.....
Drag Race + .0005"~.0010"
Forced Induction/Nitrous + .0010"~.0015"
Circle Track/Road Race + .0005"~.0010"
Marine Applications + .0010"~.0020"
Filled Block + .0010"~.0020"
So it looks to me like the max clearance advised (with 2618 alloy) would be in a marine or filled block application with a figure of 0.0065". Max clearance 400 small block in an automotive application with unfilled block (2618 alloy) would be 0.0045".
The other thing I wondered about is the stack height. Assuming you're using 6" rods and a 3.832" crank, the stack is 8.968". That means a pretty good whack off the decks to get to a good squish unless you're able to find some really thin head gaskets. Whacking the deck a bunch will mean paying very careful attention to the manifold/head interface match-up to make sure you have a seal there.
Old 03-08-2009, 04:15 PM
406 bug's Avatar
9.82 @ 139mph
Good detail/ info Tech.
Old 03-08-2009, 08:13 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Remove the gapless rings and place them in the nearest trash can. In order for the top and second rings to seal properly requires that some gases pass by the rings and create low and high pressure areas in the right spots. Gapless rings don't let enough of the gases to pass through for the rings to seal. Yeah they only leakdown 1% or whatever, but that means nothing when the motor is running.
Old 03-09-2009, 06:06 PM
Really gapless rings are that bad ive done very little research on them, they are just what came on the pistons. I dont think i wanna reuse them but im not sure yet.
I measured every cylinder this morning. Best was 4.136 and worst was 4.142.
They average .00035 out of roundness so less than half a thou on all of them.
I think I may give it a try if the machine shop will bore them all to that size. Worst case it runs poorly and I have to rip it down again, only thing lost is my time and cost to bore twice.
ford 4.6 2v piston to valve clearance sheldonw Engine 1 07-30-2008 01:39 PM
QJet Power Piston Won't Come Out of Bore JohnTN Engine 1 06-01-2006 05:38 PM
350 Piston Bore Silver_Camaro Engine 9 03-21-2004 09:00 PM
how to prepare a block blndweasel Engine 14 08-15-2003 12:28 PM
piston clearance stangfiend Engine 3 12-06-2002 07:30 PM
