piston dome - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2004, 04:29 PM
firestone's Avatar
http://teamrfc.gospelcom.net
piston dome
If you have a .100" dome piston, how many cc's is that ?
thanks
Old 02-19-2004, 05:24 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
I'd have to know the diameter of the piston and if this was a dome uniformly over the top (like hemi pistons) or a raised portion( like Chevy pistons). ...Actually the manufacturer should know, if you know the model No. ...Mark
Old 02-19-2004, 06:51 PM
mstngjoe's Avatar
The formula for converting cubic inches to cc is:
cubic inches x 16.387 = cc.
I do not know if this would be accurate for a piston dome though. Normally, when you see a dome listed at .100 it will also have the cc of that dome. Because of the varied shape/area of a domed piston, I should think the equation would probably not be helpful.
As stated above, the piston maker should have the info you need and probably on their website.
