Piston ID number - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2012, 06:31 PM
Piston ID number
Long story short, last October we installed a rebuilt 351C 4V long block
in my '71 Grande. Old engine cracked its block and we found this Cleveland.
The only info we have about the engine is we measured valve lift at 0.58
and we could read some numbers on a piston. My question is what the
numbers mean; H555CP is cast aluminum for a Cleveland, the .030 is
obvious but the numbers '201-01-14-' I can't place.
So, H555CP and 201-01-14- .030
Just put a Holley 770 on this engine and it loves it
I thought I bought a stock Cleveland but maybe not.
mike
Old 07-03-2012, 06:56 AM
That is a hyper-eutectic cast Speed Pro/Sealed Power piston for 351C. A 67 CC chamber yields a static compression ratio of 9.68:1 (.030 over). The other numbers are "job" numbers for reference.
Decent piston, not for use with nitrous...
Jim
Old 07-03-2012, 09:17 AM
Piston ID
Ok, Thanks Jim.
Wish we had the Cleveland book when we installed the engine.
Would have taken a closer look at what the rebuilders did.
The 0.58 lift cam is interesting and this Cleveland is a quench head.
mike
Old 07-03-2012, 02:03 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Speed Pro ZH555CP - Speed-Pro Hypereutectic Pistons - Overview - SummitRacing.com
Top Dead Center using number 8 piston Jake_Dragon Engine 15 05-29-2006 02:57 PM
Piston number question kohle1ce Engine 3 04-30-2006 01:34 PM
piston number 78 chevy truck Engine 27 06-24-2004 12:26 AM
piston part number confusion Sleeve396 Engine 0 04-13-2004 09:03 PM
piston number 78 chevy truck Engine 1 01-24-2004 09:44 AM
