Piston Identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2007, 10:46 AM
Is there any way to identify a piston from the back side? Did the manuafcturers cast different patterns in the back?
I pulled the pan on the '78 454 that I picked up and it is very clean. Must be a recent rebuild.
I would like to calculate the compression but would rather not pull the heads unless it is necessary.
I tried to look thru the spark plug hole with a scope. They are flat tops with small cuts to clear the valves. I can only see one side and can't identify any markings.
Old 05-23-2007, 06:47 PM
BOBCRMAN@aol.com's Avatar
Some aftermkt pistons (such as SterlingandBadger) have markings cast into the inside shirt area with a number. Some in the outer pin/skirt area (KB/Silvolite) Some etch or stamp the tops (Seal Power/TRW/FED MOG). And then some ink the tops, Good luck!
Old 05-24-2007, 06:37 AM
I did some more digging last night. The inside of the skirt is marked with the letters DD and USA. I decided to try the scope one more time and was able to see the P1545 030 on the piston tops. There were two small reliefs for the valves and a small hole on the side. I went onto summitracing.com and found that they look like the Speed-Pro Hypereutectic Pistons. Noticed that the skirt is coated on the web and when I checked mine they were. Tried to search that number on the web but came up empty. Looks like they have several .030 over pistons some are 0cc and some +2cc.
stroke to rod ratio jacobm99 Engine 28 12-16-2013 05:46 PM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 03:10 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
