-   -   piston identification (http://www.hotrodders.com/forum/piston-identification-230390.html)
RB67SS 03-06-2013 05:14 PM
I have an 1980 era GM crate motor 454 the stamping numbers on piston dome are 3999295 with GM also i am running 118cc heads.. I need help with static compression? Thanks Randy B.
BOBCRMAN@aol.com 03-06-2013 05:34 PM
A bit under 9-1 depending on factory machining variants.
2speed_1 03-06-2013 05:39 PM
piston id.
this is from the GMPP catalog. 1971 LS-6 std bore 9:1 comp closed chamber pressed in pin i think the head cc's around 106 - 108
vinniekq2 03-06-2013 06:14 PM
LS-6? I thought they were 11:1? my LS-5 was 9:1
BOBCRMAN@aol.com 03-06-2013 06:49 PM
1971 was first year for low compression high-perf BBC
RB67SS 03-07-2013 09:30 AM
update cyl heads are 6272990 118cc open chamber with 3999295 pistons which are supposed to be for a closed chamber head ? any ideas on the compression ratio with this set up? Thanks Randy
BOBCRMAN@aol.com 03-07-2013 04:33 PM
990 head is similar cc to heads that were originally used with that piston. Hence the 9-1 rating.
cobalt327 03-07-2013 05:18 PM
About 9.3 w/a 0.041" quench distance, 0.030" over 454, 118cc heads and the 14cc domes.
