piston identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2013, 06:14 PM
I have an 1980 era GM crate motor 454 the stamping numbers on piston dome are 3999295 with GM also i am running 118cc heads.. I need help with static compression? Thanks Randy B.
Old 03-06-2013, 06:34 PM
BOBCRMAN@aol.com's Avatar
A bit under 9-1 depending on factory machining variants.
Old 03-06-2013, 06:39 PM
piston id.
this is from the GMPP catalog. 1971 LS-6 std bore 9:1 comp closed chamber pressed in pin i think the head cc's around 106 - 108
Old 03-06-2013, 07:14 PM
vinniekq2's Avatar
LS-6? I thought they were 11:1? my LS-5 was 9:1
Old 03-06-2013, 07:49 PM
1971 was first year for low compression high-perf BBC
Old 03-07-2013, 10:30 AM
update cyl heads are 6272990 118cc open chamber with 3999295 pistons which are supposed to be for a closed chamber head ? any ideas on the compression ratio with this set up? Thanks Randy
Old 03-07-2013, 05:33 PM
990 head is similar cc to heads that were originally used with that piston. Hence the 9-1 rating.
Old 03-07-2013, 06:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
About 9.3 w/a 0.041" quench distance, 0.030" over 454, 118cc heads and the 14cc domes.
Rod and piston identification zildjian4life218 Engine 20 09-18-2009 10:58 PM
Piston Identification and Specification Jobob Jr Engine 4 12-14-2008 04:09 PM
Piston Identification dsolomon Engine 2 05-24-2007 07:37 AM
Piston Identification. Please Help! dastone Engine 5 11-28-2005 11:14 AM
Piston Identification -chevy?- blackjack Engine 1 10-10-2003 03:17 PM
