-   -   Piston info (http://www.hotrodders.com/forum/piston-info-157045.html)
Hacksaw 04-18-2009 10:57 AM
Piston info
I have a set of trw L2300 forged pistons .030 over bore. Anyone have any idea the compression specs? With closed chamber headsnor open chamber?
curtis73 04-18-2009 11:16 AM
We need WAY more info; unless you expect us to do a search for what those pistons fit (BBC?), guess on your stroke, and then give you a range of what the compression might be for all of the 30 or so possible chamber volumes, you gotta give us a LOT more info. Right now the best answer we can give you is somewhere between 6:1 and 15:1
What stroke, what engine, which heads...
Hacksaw 04-18-2009 01:55 PM
sorry. 427 BBC heads are large oval open chamber and a set of large oval closed chamber.
MrChevy 04-18-2009 03:43 PM
Factory they were listed at 10.25:1 in stock configuration. I think they had 104cc heads on most of those engines. They have a 16.8cc dome on them. I have a new set lying out in the shop, just a stock Forged replacement piston from the 385-400hp engines back then. Came in everything from 4 door cars to Corvettes with 3 two barrels.
With a 119cc head (open chamber) you would probably be in the 8.8:1 ratio with a .005 DCV, .040 gasket. Zero DCV would put you at about 8.9:1.
