Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston Pin Lock Rings
Old 07-30-2003, 04:59 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
You say piston pin lock rings, I am assuming you are talking about wrist pins. If so, they require a machined groove in the pistn skirt to function properly. Also the fit between the piston skirt ,wrist pin, and rod has to be precise. An engine that has pressed in wrist pins will not use locking rings.
Vince
