piston question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2011, 04:44 PM
jmaine83's Avatar
piston question
are flat top pistons is really flat? Today i pull my 416 heads off my 305 to see flat pistons is this a average 305 block thanks
Old 12-30-2011, 04:59 PM
DoubleVision's Avatar
Some 305s came with flat top 4 valve relief pistons from the factory.
Old 12-30-2011, 05:20 PM
jmaine83's Avatar
mines have 0 valve relief so is it plan flat top or dished pistons
Old 12-30-2011, 05:35 PM
techinspector1's Avatar
Wiki Edits: 326
Are you saying the piston if table-top flat with no valve reliefs?
Old 12-30-2011, 06:12 PM
jmaine83's Avatar
yes table top flat but the outside edges a lil thicker
Old 12-30-2011, 06:38 PM
Wiki Edits: 326
Then it's not table-top flat, it's a dished piston. I don't care for those OEM pistons because of the lack of a suitable squish pad.
Here's a flat-top with valve reliefs....
http://www.google.com/imgres?hl=en&b...t:429,r:7,s:18
Here's a typical Chevy piston, two eyebrows and a dish. You can see that there is insufficient material to mate up with the underside of the cylinder head to create a good squish....
http://www.google.com/imgres?hl=en&g...t:429,r:15,s:0
Here's a flat-top with no valve reliefs, you buy them and cut your own valve reliefs depending on valve angle in the heads and valve lift....
http://www.kb-silvolite.com/kb_car/p...etails&P_id=50
Here's a KB dished piston. Note the generous squish pad on the left side of the photo that mates up with the underside of the cylinder head...
http://www.kb-silvolite.com/kb_car/p...tails&P_id=154
Old 12-30-2011, 07:18 PM
jmaine83's Avatar
thanks tech 1
Old 12-30-2011, 07:45 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
So which do you have?
Semper Fi
Old 01-01-2012, 01:12 AM
Wiki Edits: 326
He has apparently decided to resist disclosure of that particular information.
Piston Question 803Paul Engine 5 11-08-2010 12:37 PM
Piston Question maxpower_454 Engine 12 03-03-2009 12:09 PM
piston question 1969NovaSS Engine 1 10-23-2005 09:39 PM
Piston question?? HemmiGremmie Engine 1 08-28-2004 06:09 PM
Piston question daves1969mach Engine 4 08-04-2004 09:40 PM
