Depends on what shape the others are in. I would also try and find the root cause of why the 2 pistons are damaged. if you just replace 2 you`ll have to carefully rehone the 2 cylinders and make sure you use plenty of lube like WD40 to keep the hone dust down. then afterwards clean the 2 cylinders and clean them until you can`t get any gray color on a paper towel. Then I would use carb spray to clean the bottom end of the engine good to try and clean everywhere else before I reassembled.
There are two ways to look at this problem. One is to determine the root cause and fix that then just replace the two bad pistons. This is the cheap way out, however to do it right the pistons must be from the same manufacturer and have the piston/rod combination weighed and have the weight matched to the units that were removed. This is the "poor man's" method of not ruining your engine by running it out of balance.
The right way to do this is to fix the root cause and then replace the entire set of pistons. Because your engine is a stroker it is important to have the rotating assembly properly balanced. The method mentioned above will work but isn't perfect and still may create some vibrations. Replacing the entire set of pistons and having the rotating assembly balanced is the only "correct" way to ensure longevity and reliability. |
| big block chevy piston to wall clearance question | Ratoflic | Engine | 24 | 06-22-2006 04:16 PM |
| Question about factory replacement parts and primer | makaveli200369 | Body - Exterior | 2 | 05-01-2006 08:40 PM |
| Piston number question | kohle1ce | Engine | 3 | 04-30-2006 01:34 PM |
| Quick speed pro piston question.. | 357ford | Engine | 2 | 10-21-2004 05:53 PM |
| Piston question?? | HemmiGremmie | Engine | 1 | 08-28-2004 05:09 PM |
