Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston ring choices - Iron Vs Moly Vs Chrome
Old 02-18-2013, 11:46 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Used bore with minimal wear, graze breaker or berry bush hone= cast rings.
Fresh straight bore properly honed for moly rings= instant break in.
Straight bore with proper finish= Chrome rings. For heavy duty, constant heat/load. Take longer to break in. Will last longer under the right conditions. No tolerance for dirty air/oil.
