Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston ring choices - Iron Vs Moly Vs Chrome
Old 02-19-2013, 12:18 PM
hcompton's Avatar
hcompton hcompton is online now
Old & Furious
I use hastings cheap cast/ moly rings. Most rings packages have more than one type of ring usally the top and bottom compression rings are different.
Now 87 ford may have low tension piston rings from the factory. If stock bore is being used it would be best to use ford factory rings.
