Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston ring choices - Iron Vs Moly Vs Chrome
Old 02-21-2013, 11:40 AM
64nailhead's Avatar
64nailhead 64nailhead is online now
Originally Posted by Torque454 View Post
So what would you recommend for a Std OEM bore with Std OEM pistons and little wear on both? There is no ridge in the cylinder wall but there is some minor scratches that you cant feel with your fingernail.
I'm gathering from all the posts that I should use either Iron or Moly, but not sure exactly which. I may decide to just leave the rings alone as good as the cylinders are (no ridge, no smoke, plugs are light brown in color, compression was 165-175psi across the board)
Thanks for the info!
If you are replacing the pistons, then do not consider reusing the rings. If you are going 'glaze bust' the cylinder, then do not consider reusing the rings and I would say to use iron rings if you are not reboring - IMO.
