Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston ring file?
Old 02-02-2009, 04:07 PM
weirdbeard's Avatar
weirdbeard weirdbeard is offline
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Piston ring file?
I just would like to know what most of you use for filing your piston rings to achieve the proper end gap. I am finding very little info on the subject, which is weird because it seems very important now that I understand it.
I have searched all the local parts stores and cannot find a piston ring file/grinder.
I could order one of the small hand crack grinders, but it is pricey and looks like it would be easy to build if I knew what grit to use. Also I only need to file 4 rings!
I also bought a small hand file that is for cleaning points type ignitions. I may try that, but I wanted some input from you guys first.. These are wisco rings for a V twin and a not cheap. I want to get it right the first time..
Thanks.
