Unless you build more than several engines a month, many people might no invest in a crank style filer. Doing it with a hand file is very time consuming. And if you need to file a set of stainless rings, its very tough to do it by hand. I have a motorized ring file, and it can still take upwards of 45 minutes to do a set,depending on how much material you have to remove. That of course is a set of "file to fit" rings, not a set of .030 over rings for a .030 over bore, where very little might need to be ground off if any.
