Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston ring file?
Old 02-08-2009, 08:48 PM
CNC-Dude CNC-Dude is offline
You will just grind off of one side of the ring! Doing it off both sides doubles your chances for getting the gap crooked. Also, make sure the ring sets square in the cylinder when you are checking the gap. I usually make a ring squaring tool for the bore size I need to do this so you can stay consistent each time you insert it into the cylinder....
