Piston ring installation instructions missing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2008, 09:07 AM
Last journal entry: Better late than never
I am rebuilding a 292 Y block that is starting to make me think it is jinxed. Everything has gone wrong (had 3 sets of main bearings, TWO sets were the marked with the wrong size).
I am now fitting the nice new pistons and rings and lo and behold the statement on the piston ring box "detailed instructions inside" is wrong, there are none.
So, I have Grant P2119 rings, the three piece oil ring has a green and red tab on the center piece. Does anyone have instructions or the ability to provide an abridged version of them for me., I want to ensure I fit them correctly.
I did do a google search but came up empty handed.
Many thanks for any input,
Paul
Old 06-21-2008, 09:51 AM
Holder350's Avatar
Auto Parts Professional
here you go.....they are all pretty much straight forward.
http://www.ehow.com/how_2142568_inst...ton-rings.html
Old 06-21-2008, 09:53 AM
Contact GRANT using the info below for that application...
For additional information, please contact us: Grant Piston Rings 1360 N. Jefferson Street Anaheim, California 92807 U.S.A. Telephone: (714) 996-0050 Email: info@grantpistonrings.com
Old 06-21-2008, 10:18 AM
Thanks guys, I have the rings on now but am unsure as to whether there are any specific details as to where the gaps should be. I know most rings need to have the various gaps offset form each other.
If this isn't critical I will just ensure they are all in different places.
Thanks again.
Old 06-21-2008, 10:22 AM
Do you have all the rings in the correct position? Are you 100% sure they are installed correctly?
Once the motor fires the rings will rotate in the bore anyway.
Old 06-22-2008, 07:41 AM
Thanks stroke, luckily the grease paper each set of rings were stored in had some brief details about which was the top/2nd ring etc and which way up so I am OK in that regard.
The fact they rotate anyway leads me to believe I just need to ensure the gaps are in different places and all should be fine.
Thanks again,
E-Z Power Converter I cant find the installation instructions Rob Keller Electrical 15 04-03-2015 10:40 AM
Need help,Pontiac 400 BEN24 Engine 4 09-05-2007 01:26 PM
Pete Jackson Gear drive installation instructions Mike 767 Engine 2 08-22-2007 02:10 AM
big block chevy piston to wall clearance question Ratoflic Engine 24 06-22-2006 04:16 PM
4 Bar Installation Instructions walmor Suspension - Brakes - Steering 1 06-07-2003 02:46 PM
