Piston ring orientation - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2010, 02:45 PM
I am reassembling my zz4 this weekend I am using stock zz4 piston PN 10159436 and stock zz4 rings.
Does anyone know the orientation for the piston ring gaps I know that the top ring is 180 degrees from the second ring but what about the third set should the three gaps line up or should they be spread out.
Old 03-25-2010, 05:07 PM
302 Z28's Avatar
Never line up gaps, even on the oil control ring. I stagger all the gaps about 180 degrees.
Vince
Old 03-25-2010, 07:17 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
the two top rings should be 180 off from each other and the gaps should line up with each side of the wrist pins. The bottom three parts of the oil ring should be 120 degrees apart.
Old 03-25-2010, 10:42 PM
406 bug's Avatar
9.82 @ 139mph
Just randomly spread them around. Once the engine has run a while they are constantly on the move.
piston help, and or ring help blake carstensen Engine 2 12-08-2005 08:25 PM
Ring Orientation Question thenige Engine 6 10-24-2005 06:35 AM
Bent Piston Ring --USABLE???? HELP 71gtx Engine 5 08-07-2005 12:57 PM
Can I replace only the top piston ring? KeithB123 Engine 12 03-24-2004 02:33 PM
Piston Ring Spacing MHenricks Engine 4 09-09-2002 06:38 AM
