Piston Ring Placement???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2012, 05:04 PM
Newbie...first rebuild.
I purchased a set of Sealed Power Rings #E-251K-40 from Summit. The install directions show the top ring as having a inner top bevel or a outer tapered face and the second ring as having a inner bottom bevel (depending on the kit). The set does include rings with a inner bottom bevel so I suppose these are the second groove rings however the other set of rings in the kit have no taper or bevel at all. So, by way of elimination the squared (plain, no bevel, no taper) ring must be the top groove ring. Does this seem correct? The rings I removed from the pistons both have inner bevels. Top ring is beveled on top and the second ring is beveled on bottom.
Thanks
Willy
Old 01-01-2012, 05:39 PM
techinspector1's Avatar
Wiki Edits: 326
Hello Willy, is there a mark of any kind on the ring showing "up"? If not, I'd use another set of rings that are properly marked. Trust nobody.
"Top ring is beveled on top and the second ring is beveled on bottom."
That's the way I remember it.
Old 01-01-2012, 05:47 PM
BOBCRMAN@aol.com's Avatar
It is common for that set of rings.. The top ring is a plain ring. Unlike Hastings and others. No markings. Installs either side up. Second ring has a dot on top side.. Dot up..
Old 01-01-2012, 05:50 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
Willy
Look VERY carefully at the second ring for the pip mark (aka "dot"). It's there, maybe an inch or slightly less from the end of the ring- just hard to see compared to the top ring's pip (if present).
Old 01-01-2012, 06:37 PM
I believe I've been misunderstood. The issue is not which side goes up. Both sets are marked with the dot for top side. No problem. The issue is top groove and second groove on the piston. The install instructions show (diagram) two sets of rings with beveled edges. But the box has one set with beveled edge and one set squared, no beveled edge. I want to make sure i put the compression rings in the top grooves.
Old 01-01-2012, 06:44 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
Willy
Ring w/inner bottom bevel is the second compression ring. The other is (obviously) the top ring.
http://www.federalmogul.com/korihand...section_18.htm
Old 01-01-2012, 06:51 PM
Thanks Guys. I just ran across some more info. I've got it all figured out.
I appreciate the help.
Willy
Ring gap placement..... 383SBC Engine 5 05-30-2011 08:15 PM
383 Piston Ring Placement callmej75 Engine 11 05-13-2011 05:37 PM
700r4 - reluctor ring placement praevalesco Transmission - Rearend 4 10-03-2010 08:31 PM
Piston Placement sexypizzaman Engine 5 05-30-2007 10:56 AM
help w/ placement of piston rings 69'skylark Engine 2 06-22-2004 09:21 PM
