Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - piston rings 1/16 vs 5/64
Old 09-22-2011, 12:47 PM
lg1969's Avatar
lg1969 lg1969 is offline
Google "Tunnel Ram 406"
Cobalt327 is correct on the rings. The thinner ring are for racing to reduce friction and reduce the heat it generates at high RPM. It's used in NASCAR racing. The problem is you will get more blow-by and consume more oil if it is used for street use.
