piston rings to use on a rering job
i've got a low mileage chevy 350 crate motor ( '80 - ' 85 ' 2-piece ) that was taken out of a vehicle . the motor was cleaned & three cylinders had water left in them & it set long enough to be stuck , but i was able to remove the stuck piston & rod assembly's after soaking all the cylinders in transmission fluid . the rings are stuck mostly due to carbon . i'm gonna install new rings & bearings while i have it apart , but i'm not sure which rings i need to use , cast or moly . the cylinder walls cleaned up with a scotch brite pad & a very little ridge is in each cylinder . pistons are tight , but i don't want to put it together with-out new rings & bearings . the crankshaft & bearing look real good , but as cheap as they are it would be best to install new bearings . one more question , is it o.k. to glass bead the pistons to get the carbon out of the ring grooves ? i have glass beads or media in my blasting cabinet , not sand . any help would be great , thanks , grumpy aka : grumpysdeuce
YUP! Cleaning oil pans/valve covers with glass bead or sand is just a big NO NO. As for pistons, been cleaning them with bead for over 30 years and no problems. Do not shoot the ring lands! Use a ring groove cleaner or a broken off ring if you must.
Cast Iron rings only! on a re-ring job with questionable bores. |
I would probably remove that ridge with a ridge reamer to make sure I didn't break a new ring. Be careful not to scratch the cylinder wall if you decide to do it. If you go with the moly rings make sure you hone those cylinders with a much finer grit stone than you would use with reg steel. I can't remember what grit to use off of the top of my head but the walls need to be pretty slick
| 383 vs 350 | TheCiscoKid | Engine | 86 | 05-03-2008 03:10 PM |
| 327 in 88 Truck | pete379 | Engine | 101 | 01-19-2006 09:03 PM |
| Damaging the Piston Rings. | Hot Rod/SS | Engine | 5 | 10-06-2003 05:53 PM |
| Broken piston rings | willys36@aol.com | Engine | 4 | 08-12-2002 07:32 PM |
| Cracked piston rings!! | tjk2000us2000 | Engine | 4 | 08-03-2002 09:52 AM |
