Piston Stop, No Directions - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2005, 11:40 AM
BigDawgsEatFirst's Avatar
400SBC4Life
I just got a Spark Plug Hole Piston Stop
to locate TDC
I has no directions and it is adjustable
How far down in the hole should it be.
Thanks ,
BDEF
Chevy Small Block -350
Old 09-23-2005, 12:23 PM
It only needs to be far enough down to stop the piston prior to TDC. What are you trying to do? Verify harmonic balancer position versus timing pointer? If so then roll the motor over to 5 to 10 after tdc, or before TDC and install piston stop and lightly bottom it against the piston. Roll the motor over the opposite direction and note position on the balancer when lightly seated on the stop. Roll the motor over the other way, again, and note position on balancer. Split the dif and that's TDC. Adjust pointer and reverify.
Old 09-23-2005, 12:44 PM
400SBC4Life
Someone put a 305 blancer on a 350
the timing marks are at 3 or 4 oclock
when tdc is at 12
thanks,
big dawg
Old 09-23-2005, 12:58 PM
Are you sure there are different balancers of a 305 and 350? You might want to check to see if the balancer has spun or slipped a little. This did happen to me. The balancer has a rubber center that can break and allow the outer ring to move thus moving the timming mark. My brother had a heck of a time timming my truck. I forgot to mention to him that a mechanic told me the balancer had moved.
stroke to rod ratio jacobm99 Engine 28 12-16-2013 05:46 PM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 03:10 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
