Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston stop without timing tab
Old 09-09-2012, 10:50 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
Originally Posted by Novabuilder113 View Post
I could just go get one but a lot of the aftermarket ones have adjustable mounting slots and I would still need to know exactly where to point it in relation to the balancer.
That would make it even better and easier being adjustable, especially if you didn't know the exact balancer diameter or application, you would still need to locate TDC like you described, then move the scale to that point. Just the same as degreeing a camshaft.
Semper Fi
