Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston stop without timing tab
Old 09-09-2012, 11:04 PM
Novabuilder113 Novabuilder113 is offline
Originally Posted by 68NovaSS View Post
That would make it even better and easier being adjustable, especially if you didn't know the exact balancer diameter or application, you would still need to locate TDC like you described, then move the scale to that point. Just the same as degreeing a camshaft.
So the procedure I described is correct as far as Finding tdc on the pulley and Transferring it to the cover, tab, ect?
