Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston stop without timing tab
Old 09-10-2012, 06:51 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Novabuilder113 View Post
I actually have a light with built in advance so I'm just concerned with tdc. The time light will do the rest
There were three commonly used SBC timing tab/damper lines. They are described HERE.
A page on finding TDC is HERE- although the way you described is just fine for getting the timing tab and damper line within a degree or so.
BTW, if you find that the damper you has the keyway in the 2 o’clock position- or 10º before the damper line, that's the tab that's commonly available at the parts store on the "High Performance" isle.
Good luck.
