Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston stop without timing tab
Old 09-10-2012, 08:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Something else that's a good idea to do- and easy- is to mark the outer ring of the damper to the inner hub to be sure they're not slipping relative to each other. Put the mark near the damper TDC line so the lines are visible w/a timing light and the engine running.
The Following User Says Thank You to cobalt327 For This Useful Post:
Novabuilder113 (09-10-2012)
