Piston suggestions
Okay guys here we go,when I started my project (1980 2dr Malibu) I "intended" to go with something simple a stock 454 BBC(361959)with (336781) 113cc heads & a cam. Then I found out that if I had it bored .060 I culd make it a 468, next with alil feedback from yu guys I was informed that with 2.19x1.88 valves I culd take my heads up to 119cc. Well with alil research of my own & a performance chart from my69z28.com I've discovered I can take it higher up to a 496 with an addition of a 4.250 crank, mild has slowly turned into wild! I figure I'll go with this set-up & let a real mechanic figure out the best cam that'll work with it best but my question is, goin with this set-up 454 (361959) block, (336781) heads with 2.19x1.88 valves, and a eagle 4.250 cast steel crank if I was to use flat top .060 pistons wuld they be sufficient? If not, why & what kind wuld yu recommend?
(I dnt know any of the compression ratios or how to calculate them) |
I have a 400 Chevy transmission goin behind it, haven't selected a converter yet. But I plan on putting a 8.5 posi with 3.73 gear. I shuld remind yu guys this isn't intended to be a strip car, jus something for the weekends...
Piston suggestions
MalibuMike, I would like a little more understanding of the use of the 1980 Malibu. How much of a budget do you plan for the rotating assembly? When you have the block bored be sure to "0" deck it too. It makes setting the quench easier. If you don't want to "0" deck it, check on head gaskets you can get that added to deck clearance = .040. You need to have all the work done to the heads and cc the chambers. You need the chamber size to figure your compression ratio. Are you going with cast parts or forged parts for the rotating assembly, it is up to you.
Piston suggestions
Check out a rotating assembly like this one. With the cast iron heads I would not get a rotating assembly with a C.R. of 10.2. You can always mill the heads to 115cc to bring the C.R. up. Scat 1-91505BI BB Chevy 496 Street And Strip Performance Balanced Rotating Assembly - 8.6:1 Icon Flat Top Pistons - BB Chevy 496 Kits - Rotating Assemblies - New | CNC Motorsports | Car Parts | Truck Parts | Competition Engines
Welp, looks like cdminter59 has jus completed the rest of my engine build in one simple post lol thanks guys
Agreed with the kit shown as long as revs are kept "down". We've seen issues with the cast cranks in BBCs when revved above about 6,500. The 4.25" is bad for it. If you're looking to make serious power, spend the extra bucks for a forged crankshaft. We like Eagle, but others have success with Scat, etc. There are American-made BBC cranks, but be prepared ($$).
If a power build, put as long a rod as will "fit" in there. Probably 6.385". Jim |
Yea this was a budget build, wasnt really trying go too extreme but thanks to yu guys I will be able to step it up quite a bit for around the same price range. I'll be sure to post a few pics/vids when it's finished.
use this kit.
Eagle 18022L BB Chevy 496 Street and Strip Rotating Assembly - 10.2:1 Mahle Dome Pistons - BB Chevy 496 Kits - Rotating Assemblies - New | CNC Motorsports | Car Parts | Truck Parts | Competition Engines with the following: Edelbrock RPM intake 850 holley headers and 3"dual exhaust 1.72 roller rockers with tall valve covers Compcam 292H with the proper valve springs 10 inch converter with a 3000 stall Hei with MSD conversion 6000 rpms should be max. |
| Old TRW Piston Part # 234-98 396 Chevy Forged Piston? | heathj1 | Engine | 1 | 07-21-2009 05:14 PM |
| 327 piston suggestions. | dfgunner | Engine | 16 | 04-07-2009 02:39 AM |
| positioning piston rings on piston | geormor9 | Engine | 5 | 03-21-2009 05:33 PM |
| RE:Flat Piston To Domed Piston | Bgcooley | Engine | 10 | 09-04-2007 12:59 PM |
| 302 piston dim. compared to 327 piston | Dave Y. | Engine | 2 | 09-25-2002 08:55 AM |
