Piston surface volume
Having stock dished 350 pistons with 4 valve reliefs what is my approx volume in CCs.
Take a read of this.
Quote; Piston shape also plays a big role in compression. A pure flat-top piston does not affect compression—but rarely occurs in the real world. Even a “flat top” piston incorporates valve reliefs in the piston top that add volume. A typical small-block, four-eyebrow piston contributes roughly 4 to 6 cc’s worth of volume. This is the same as adding that amount to the combustion chamber size. |
I have the piston pulled and in hand, It is a replacment piston and its 60 over. How would I get the volume from it.
I googled the numbers from piston top, 423np 060. appears to be a sealed power piston but havent found the volume, any ideas??
Mount the piston in a vise so the crown is level in all directions. Take the graduated whatever and draw a measured amount of fluid, rubbing alcohol works well, and proceed to fill the depression in the piston crown. If it helps you, taking a piece of Plexiglas with a 1/4-3/8 inch hole in it and sealing it to the piston crown with Vaseline can be a helpful pouring guide. Bogie |
Well if you can accurately measure the shape features you could mathematically calculate it. You will need the formula for volume of a torus then divide by 4 for the bottom radius.
On the other hand if you can accurately measure the form, I could draw it up on Solidworks and check mass properties which will give the volume. The best bet would be to take a picture and import it to paint or something like that so you can label the features with dimentions. Don't need to be neat or formal it's just information to me. |
maybe you can start with this info The diameter of the dish is 3.112 and .057 depth. I will work on the relief |
I usually add 5cc to the chamber volume to account for the valve reliefs in a 350, 4 valve-relief piston.
This is in addition to the value I get when calculating the volume amount from the deck clearance and head gasket volume. tom |
That should have the same volume as a H859Cp piston plus 5 cc for the 2 extra valve reliefs. I am not sure what that is, I just know the pistons are very similar. (except for the valve reliefs).
They are 9.6:1 with a 64cc head, |
how would 9.6.1 be on pump gas? I am not a motor guy and trying to build a 350 for a roadster. I have a 350 thats bored 60 over, i have a set of 60cc 305 heads(416) and a set of 76cc 350 heads(882s). Dont want big HP, just something I wont have to be tweaking all the time. I want to use what I have and not spend any money, suggestions???
Pretty shallow depth.
Assuming a 3/32 radius at the bottom and tangent to the bottom, and a full circular dish, You have 6.89 cc so far. If it is D shape all I need is the distance across the circle to the flat. For valve reliefs I need the number, the diameter, the length of the cut perpendicular to the face of the cut and the angle to the top of the piston. Either side of the angle will do, I can use either. Instead of the angle you could give me the length of the machined relief... ie the distance from the straight side to the diameter. I may be able to position this so it works out. EDIT Try to give me the spacing of the valves as my car is miles from me. thanks I can try and paste a picture if you give me this stuff. |
Ok I've got a valve relief plugged in but I need "real" dimensions.
Also let me know if the valve reliefs are different or if it is a "slash" type of relief. Thanks for giving a retired eng something to do. haha enjoy |
bentwings
I dont mean to take your fun away, but I used a syringe my RN wife had and we dropped water on the head and came up with 15cc. Im not sure how I can even measure the relief? Last edited by BadA$$37; 01-02-2008 at 06:27 PM. |
Good going!! Medical supplies for automotive understanding. I like it.
I think the pistons I mentioned earlier are 12cc so you could expect 10 to 1 compression with 60cc heads. As long as the pistons are less than .015 below the deck at TDC then I would say go with the 60cc heads this will give you around 10:1 which should work with pump gas. The 76cc heads will drop your compression to like 8:1 which will give you horrible performance, That street rod would run the best with the 416 heads and premium gas and if the compression was a little to high you could back off the timing or add a 4 dollar bottle of octane booster when you filled up the tank. Unless you were planning on adding a supercharger then you would want that 8:1 compression. There are a lot of possibilities when building a motor and all the parts have to come together just right to make decent power on a budget. But it is not unreasonable to expect good numbers, run on pump gas, and not break the bank building it. |
| stroke to rod ratio | jacobm99 | Engine | 17 | 09-16-2010 10:06 AM |
| 383 vs 350 | TheCiscoKid | Engine | 86 | 05-03-2008 03:10 PM |
| Roller Rockers | Redneck914 | Engine | 5 | 06-27-2007 04:36 PM |
| 327 in 88 Truck | pete379 | Engine | 101 | 01-19-2006 09:03 PM |
| longest rods in std deck 454 bbc?? | deuce_454 | Engine | 11 | 01-30-2004 10:06 AM |
