Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - piston to valve clearance
Old 08-14-2012, 12:15 PM
Huneycutt's Avatar
Huneycutt Huneycutt is offline
You should definitely check it manually like was already recommended. Exhaust valve at 10 degrees BTDC and the intake at 10 degrees ATDC. Even if it is a pain, it's a lot better than fixing all the damage that comes with a broken valve.
