Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - piston to valve clearance
Old 08-14-2012, 03:58 PM
bigdog7373's Avatar
bigdog7373 bigdog7373 is offline
Of course it's fast
Originally Posted by dave350v8 View Post
Thanks for that, im still running standard ratio rockers,but now rollers.
Its looks like I will be ok then! If I end up taking heads off to clearance the pushrod holes then I will check with some clay,just in a rush to get it done,got 2 weeks before I take it down the strip...
Don't rush too much, that's how you make mistakes. Good luck with your build
