Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - piston to valve clearance
Old 08-15-2012, 09:50 AM
dave350v8 dave350v8 is offline
Originally Posted by cobalt327 View Post
Piston to valve, while being very important, is only one of the valve train points that should be checked. The correct pushrod length should be high on your list of priorities- the p-rod length sets the valve train geometry.
The new heads should have plenty of clearance at the pushrod hole in the head; they're made to be used w/screw in studs and guide plates.
Good luck.
Thanks for the link,very good read!
