piston to valve clearance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2010, 10:04 AM
What is ok when it comes to the minimum piston to valve clearance?
Thanks
Old 06-15-2010, 10:19 AM
I have run .090 and that is a little close, but it was my motor.
I think the recommendation is .100 piston to valve.
Thanks
Old 06-15-2010, 10:54 AM
406 bug's Avatar
9.82 @ 139mph
Valve to piston .080 on intake. Exhust .100
Old 06-15-2010, 01:42 PM
Builder sent me an email saying my ex. was at .075 and my int. was at .125 I have not been able to get a hold of him to talk about a fix as of yet. What may be some things to do to fix this.
Thanks
Old 06-15-2010, 01:53 PM
ericnova72's Avatar
More for Less Racer
If your valvesprings are good for the job and you never let it get over-revved into valve float, you will be fine with what you have for clearance. Clearance recommendations of .080" intake and .100" exhaust are just to keep you out of trouble if you float the valves. I have personally run .040" intake and .065" exhaust clearance without problem, and know others who have also, but you HAVE to keep the valvetrain under control, let the springs get weak with age or use and you don't swap them out, it will bite you.
This is with a solid lifter/solid roller valvetrain, don't know as I would try to run close on clearance with anything hydraulic.
You could be fine with what you have, tell us more about the engine. Your measurements seem backwards to what is usually seen, usually the intake is the smaller clearance unless the cam has been installed retarded.
Old 06-15-2010, 01:58 PM
The usual fix is flycutting pistons.
Old 06-15-2010, 03:54 PM
Thanks for the reply's.
A little about the engine set up. It is a solid flat tappet cam .545/.554 lift 298/302 duration with a new roller valve train rated at 700 lift. I'm running 1.6 shaft rockers which push the lift up to .579/.594 The heads are Brodix track1's shaved down to 58cc. Pistons are srp 13.8:1
I thought this to seemed backwards as well. Like I said, I have not talk to him yet to get the details on how he set things up.
Old 06-15-2010, 05:14 PM
ericnova72's Avatar
More for Less Racer
If you are running Alky in circle track, then the cam spec's would be more likely to reflect what you have for clearance. From the sounds of the parts list, I wouldn't be worried about the clearance figures you have.
Like BBCMudbogger posted, the only way to get more clearance is to flycut the pistons.
Old 06-15-2010, 05:26 PM
It's an alcohol drag race app. I have a mallory 6al ignition with a rev. limiter and a msd 2 stage limiter as well for burn out and launch. It should be safe from any over rev. and valve float.
Old 06-15-2010, 05:41 PM
ericnova72's Avatar
More for Less Racer
Yep, Alcohol was the key word here, can specs will be different than a gas engine. Sounds like you will be fine.
Builder says 1/4 more on rockers....HHHMMM? sooper Engine 29 07-16-2010 01:17 PM
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 03:10 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
