Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston to valve clearance
Old 11-15-2004, 12:31 PM
Max Keith's Avatar
Max Keith Max Keith is offline
valve clearance
Where he to have a lot higher lift and longer duration in his cam, I would have recommended more clearance on the clay measuring. I do agree that probably .100" should be the minimum under usual circumstances.
