clearance
.080" intake / .100" exhaust on a steel rod engine with normal piston to wall clearance. If you have excessive piston to wall clearance the piston will "rock" in the bore a reduce the p/v clearance. If you can be 100 percent positive that the engine will never go over 6500 then you can reduce those numbers by .015" each......
If you are close make sure you check your clearance in running condition... Do not use the light checker springs.... Keith |
| 383 vs 350 | TheCiscoKid | Engine | 86 | 05-03-2008 03:10 PM |
| TH350 Manual Valve Question | Pantload | Transmission - Rearend | 6 | 02-19-2006 01:48 PM |
| Valve Clearance Question | JamesRS | Engine | 2 | 02-06-2004 09:30 PM |
| longest rods in std deck 454 bbc?? | deuce_454 | Engine | 11 | 01-30-2004 10:06 AM |
| how to prepare a block | blndweasel | Engine | 14 | 08-15-2003 12:28 PM |
