Piston-to-valve clearance checking with hyd lifters
Ok, I haven't been able to locate any checking springs locally, so will need to use regular valve springs. Also, I haven't been able to purchase a couple of solid lifters (I'm in England, remember). So, I need to work with what I have. The way I see it, I have 2 possible options...
1. Turn a couple of my old hyd lifters into solids by dismantling them and shimming them with washers? 2. Leave the lifters alone, but adjust my rocker arms with enough 'pre-load' to totally bottom-out the lifter plunger before checking P-to-V clearance? Thoughts? Tips? Thanks. |
2. Filling up an old lifter will suffice for your measurements. You don't want to preload the lifter to collapse it because what's needed is to discover the length of push rod that results in the proper sweep of the rocker tip on the valve stem. Collapsing the lifter will give a false reading. Bogie |
| All times are GMT -6. The time now is 07:50 PM. |
