We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 07-17-2008, 05:16 PM
v8hed's Avatar
v8hed v8hed is offline
Dax Tojeiro
Piston-to-valve clearance checking with hyd lifters
Ok, I haven't been able to locate any checking springs locally, so will need to use regular valve springs. Also, I haven't been able to purchase a couple of solid lifters (I'm in England, remember). So, I need to work with what I have. The way I see it, I have 2 possible options...
1. Turn a couple of my old hyd lifters into solids by dismantling them and shimming them with washers?
2. Leave the lifters alone, but adjust my rocker arms with enough 'pre-load' to totally bottom-out the lifter plunger before checking P-to-V clearance?
Thoughts? Tips?
Thanks.
Old 07-17-2008, 05:44 PM
oldbogie oldbogie is offline
Thoughts? Tips?
Thanks.
1. Get some springs from the hardware store that fit in there and are sufficient to hold the valves in a closed position, regular springs can be too stiff for the strength of a checking pushrod and will bend it enough to give distorted measurements.
2. Filling up an old lifter will suffice for your measurements. You don't want to preload the lifter to collapse it because what's needed is to discover the length of push rod that results in the proper sweep of the rocker tip on the valve stem. Collapsing the lifter will give a false reading.
Bogie
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Piston-to-valve clearance checking with hyd lifters"
Piston To Valve Clearance Problem - Help leejoy Engine 106 02-24-2008 06:12 PM
Piston To Valve Clearance Question # 258,325 leejoy Engine 5 01-07-2008 11:42 PM
Piston VS. Valve 2NDChance Engine 16 11-05-2007 04:55 AM
Need Advice on intake setup decathlete Engine 4 07-10-2007 06:25 PM
flycut piston valve reliefs groundrail General Rodding Tech 1 12-27-2004 11:49 AM
