Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston-to-valve clearance checking with hyd lifters
Old 07-17-2008, 05:16 PM
v8hed's Avatar
v8hed v8hed is offline
AK427
Ok, I haven't been able to locate any checking springs locally, so will need to use regular valve springs. Also, I haven't been able to purchase a couple of solid lifters (I'm in England, remember). So, I need to work with what I have. The way I see it, I have 2 possible options...
1. Turn a couple of my old hyd lifters into solids by dismantling them and shimming them with washers?
2. Leave the lifters alone, but adjust my rocker arms with enough 'pre-load' to totally bottom-out the lifter plunger before checking P-to-V clearance?
Thoughts? Tips?
Thanks.
