Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Piston to valve clearence help.
Old 03-05-2013, 09:47 PM
tresi tresi is offline
Isky used to make something like a fly cutter that you powerd with a drill. You installed it in the head in stead of a valve and set the head on the engine then chuck the drill on the stem. It had stops on it that you set so you didn't cut too much. Check on Isky's site if you're not wanting to go to the machine shop.
