Pistons are .032" in the hole - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2012, 08:07 PM
6426yy's Avatar
Tearing down one of my 400 small blocks and measuring the installed height of my pistons and every corner is .032 in the hole. Just wondering if anyone else has had them this bad. I used the same piston and rod for each corner. I usually get .022 to .025.
Old 06-17-2012, 08:26 PM
LATECH's Avatar
Piston pin height (compression Height) can change from different piston manufacturers. You may have an engine that was rebuilt at one time and "rebuilder" grade pistons were used. When replacing them, be sure to check the spec on the compression height to be sure you get them as high up in the hole as you can. Then you can decide to deck or not to deck and what thickness of head gasket you want to run.
One good thing is that the block must be pretty square. If you checked all 4 corners with the same piston and rod and it was the same , it must be square. Also by using the same piston/rod to measure all 4 corners you removed any variance from the measurment than could exist between the entire set of your rods and pistons. Good lookin out.
Fact is stranger than Fiction
Two "NPT" Hole Thermostat Houseing Who Makes It Viet Nam Vette Engine 25 08-20-2009 05:50 AM
"Sealed Power" pistons - good or bad?! bbjunkie Engine 14 12-01-2008 04:56 AM
how bad really, to be 032 in the hole? bullheimer Engine 20 12-06-2006 06:33 PM
rais compression without pistons "howto".need some tech advise 74chevyflat Engine 6 05-26-2006 09:21 AM
SBC "threaded hole in lifter valley" Stroker56 Engine 6 04-17-2005 08:41 PM
